egranuloma
Feb 21, 2022Aspirant
Readynas 4200 v2 Power Supply Fans Not Turning Off OS6
Unit powers on and works as expected but if I shut it down by either the web user interface or forcibly holding down the power button, the power supply fans stay on. Is there any reason why they nee...
JeraldM
Feb 22, 2022NETGEAR Employee Retired
Hi egranuloma,
The fans should turn off as well when shutting the unit down.
Were there any events that might have caused this issue? Also, did this issue occur after upgrading the NAS from OS4 to OS6?
You could also PM me the system logs to further check.
JeraldM
NETGEAR Community Team
egranuloma
Feb 23, 2022Aspirant
I never used it when it was on OS4, I upgraded it immedietly when I received it.
The only thing that is weird about this unit is this, the unit is on its own dedicated circuit with the two dedicated outlets it needs, one for each power supply. As soon as I plug it in it turns on, it doesnt wait for me to press the power button. As of now, because its impossible to plug both plugs in at the same time I turn it on and off via the breaker...
What log would you like to see, I dont think I can send you the entire zip in a PM.
Thanks
Adam
