Sandshark
Jan 31, 2017Sensei
ReadyNAS 4200V2 OS6.6.1 fan control
OK, I couldn't resist picking up an inexpensive ReadyNAS 4200V2. I ran it a short while on OS 4.2.30, then upgraded to 6.6.1. While the fans ran a bit higher than I thought they needed to on 4.2.x ...
- Feb 01, 2017
There is no RN4200v2 sensors config that ships with OS6. There aren't any RN4200v2 systems around here so I can't verify this, but you may be able to just copy the RN4200v1 config and start from there. It might "just work". Just do this:
# cp /etc/frontview/sensors/RN4200.conf /etc/sensors.d/ # systemctl restart readynasd
Skywalker
Feb 01, 2017NETGEAR Expert
Sandshark
Feb 02, 2017Sensei
Many thanks Skywalker, the force is truly with you. It made all the difference in the world. I looked at the file contents and everything agreed with what my experiments showed, I verified the fan headers were numbered the same on the V1 and V2 motherboards, and I was satisfied it should work. Once I copied it and restarted, the fans are running at a much more reasonable speed. It's been going now for several minutes, and I'll leave it on over night.
Sometimes, none of the graphs are active after a reboot. I get some spinning wheels when I first bring up the tab, then nothing. But that may have always been the case, as I have not rebooted it a lot. Another side effect of doing this is that the Overview tab now reports the unit as a 4200 rather than a 4200V2. I tried renaming the .conf to RN4200V2.conf, but that didn't make a difference. As long as it still recognizes drives larger than 2TB (and it does, as you can see in bay 10 above), I guess it doesn't matter.
If you need anything checked on a 4200V2 for a future release, let me know. I plan to move some of my backups to the 4200, but I can always pull the drives and experiment with a couple spares.
- tdatersFeb 03, 2017Aspirant
i have the issue, but am a complete neophyte when it come to entering commands in this OS. Do i just log on once it's up and running and enter the comands as you have them listed?
thanks
- mdgm-ntgrFeb 04, 2017NETGEAR Employee Retired
You'd enable the SSH service, login as 'root' (no quotes - password is set to be the same as that for the admin user but they are separate accounts) and enter the commands. Note that you wouldn't type the # at the start. That comments out the command. We tend to post commands that way as you should always think about what you're doing rather than blindly copy and paste commands.
- SandsharkFeb 04, 2017Sensei
One step mdgm left out is that you need an SSH client. Assuming you are running Windows, Putty is a good choice. Just provide Putty with the IP address of the NAS and leave the remaining defaults unchanged. The first time you log into a new device, it will have a pop-up where you verify you are logging into the device you think you are.
You could probably use the Shell in a Box app to do it as well, but I've never used that.
