Mike-73
Jun 02, 2021Aspirant
ReadyNAS 422 - MS OneDrive SYNC Problems
Having terrible problems with sync between onedrive and also my ReadyNAS 422. Tried disconnecting and reconnecting, response is slow, can create files on the onedrive which get picked up on the NAS...
JohnCM_S
Jun 03, 2021NETGEAR Employee Retired
Hi Mike-73,
May I know the current firmware version of your NAS?
You may also download the NAS system logs and check the one-drive.log. We may be able to find the cause of the issue there.
- Mike-73Jun 03, 2021Aspirant
Thanks John, thats fantastic, I responded to your email with the zip file of the logs, will this work?
