Mike-73
Jun 02, 2021Aspirant
ReadyNAS 422 - MS OneDrive SYNC Problems
Having terrible problems with sync between onedrive and also my ReadyNAS 422. Tried disconnecting and reconnecting, response is slow, can create files on the onedrive which get picked up on the NAS...
JohnCM_S
Jun 03, 2021NETGEAR Employee Retired
Hi Mike-73,
May I know the current firmware version of your NAS?
You may also download the NAS system logs and check the one-drive.log. We may be able to find the cause of the issue there.
Mike-73
Jun 03, 2021Aspirant
Thanks John, thats fantastic, I responded to your email with the zip file of the logs, will this work?
- JohnCM_SJun 03, 2021NETGEAR Employee Retired
Hi Mike-73,
You may just upload the logs to a cloud storage site then send me the download link via private message.
Regards,- Mike-73Jun 03, 2021Aspirant
PM Sent thank you.....
- Mike-73Jun 08, 2021Aspirant
Hi John,
I am still suffering silently with the NAs - OneDrive Sync problems. I have downloaded the latest log files which i hope may shed some light on the issues we are experiencing.
Lately i have noted new project files created on the NAS are not up loading to OD. Conversely also files that people are working on remotely are not syncing back to the NAS. My control panel window shows a blue light suggesting syncing and onedrive quiet often confirms everything is up to date however this is sadly not the case..
Would be grateful for any advice or assistance
M
