guitman's avatar
guitman
ReadyNAS 4220 as ESXi Datastore - NFS way slower than iSCSI
I just set up a 12 drive 4220 and began some performance testing. Just simple file read and write operations. The 4220 is connected as a datastore to an ESXi host.
I tried both as iSCSI and NFS. I like the NFS idea as I can just have one huge datastore and am not limited to 2TB LUNs. But, iSCSI is so much faster it seems.
iSCSI Write: 60-70MB
NFS Write: 16MB.
I enabled async on the NFS share, and that did nothing to help the performance. Anything else I can try to speed up NFS?
  • I have some more information, and this is not isolated to VMWare.
    If I connect to my Windows 7 and 2008 machines to my ReadyNAS 4220 using NFS, I get incredibly slow file copy performance. About 10-20MBPS. SMB to the same share is lightning fast, around 100-120MBPS. Also, NFS from a Mac is lightning fast. So, it seems VMWare ESXi and Windows are really slow connecting to NFS. I tried to move a 700MB ISO file from a local data store to an NFS datastore and it was going to take 4 minutes. From my mac it took seconds to the same NFS datastore.
    I tried this with multiple Windows machines, both physical and virtual.
  • I have a ReadyNAS 3220 running Firmware 6.1.6
    My NFS is running very very slow.
    According to VMware I have an Avg NFS Write Latency of 130ms!
    What is very odd is I have two identical ReadyNAS 3200 units using NFS on the same network with a Write Latency of 1.4ms!
    Did you ever get an answer? I read the release notes of 6.1.6 firmware and it mentioned it improved the NFS speed.
    Any help would be appreciated.
    M
ProSupport for Business
