MatthiasG
Jan 03, 2020Aspirant
ReadyNas 424 offline
Hi you All, I have a NAS 424 with version 6.10.2 and attached a HDD with 6TB to copy all data (4TB) more than 24 hours ago. Now the Nas is not reachable via IP adress (even ping does not work...
- Jan 05, 2020
After a few hours I tried a few next attempts with RAIDar but unsuccessful.
I then did a forced shutdown and a standard power on.
After booting the NAS was reachable and the last entrance on log file showed only that the backup was started.
I now reformated the USB HDD and restarted the backup by copiing the folders one by one.
I suppose that the backup process was interrupted by the start of other automated backups.
Issue solved.
Jan 03, 2020Guru - Experienced User
Can you clarify this?
Did you connect a USB hard drive to the RN424? Or did you do something else?
If so, how exactly did you copy the data? Or are you saying that the NAS locked up when you connected the USB drive???
- MatthiasGJan 03, 2020Aspirant
Ath the beginning I was not able to access the HDD (it was formated exFAT) then I reformated it as NTFS and was able that the NAS was able to recognize it.
I connected the USB HDD to the nas and did what the help page told me:
https://kb.netgear.com/29654/How-do-I-back-up-data-from-my-ReadyNAS-OS-6-system-to-a-USB-disk.
(I have chosen EXT4 as file system and Data (everything what is on the NAS (4.7 TB)).
since then the performance went down (to acces the nas from a pc) and then it went offline and still remains offline.
the lan port is flickering like hell, but it has not IP adress Nighthawk® X10 Smart-WLAN-Router (R9000) tells me.
- StephenBJan 04, 2020Guru - Experienced User
Personally I would have left it as NTFS. EXT4 likely has a small performance edge, but it can't be read on Windows or Mac PCs. For me that's a huge downside.
MatthiasG wrote:
I connected the USB HDD to the nas and did what the help page told me ...
So the backup is running?
Did you try using RAIDar to check the IP address? https://kb.netgear.com/20684/ReadyNAS-Downloads
- SandsharkJan 04, 2020Sensei
There is a EXT driver for Windows with read/write support (http://www.paragon-software.com/home/extfs-windows/ ), but I, too, recommend using NTFS for external drives.
