MatthiasG
Jan 03, 2020Aspirant
ReadyNas 424 offline
Hi you All, I have a NAS 424 with version 6.10.2 and attached a HDD with 6TB to copy all data (4TB) more than 24 hours ago. Now the Nas is not reachable via IP adress (even ping does not work...
- Jan 05, 2020
After a few hours I tried a few next attempts with RAIDar but unsuccessful.
I then did a forced shutdown and a standard power on.
After booting the NAS was reachable and the last entrance on log file showed only that the backup was started.
I now reformated the USB HDD and restarted the backup by copiing the folders one by one.
I suppose that the backup process was interrupted by the start of other automated backups.
Issue solved.
MatthiasG
Jan 05, 2020Aspirant
there is no light anymore on the HDD and RAIDar 6.5.0 says that is no Nas around.
I will try to shut it down (a forced one) in a few hours if RAIDar will not see it.
MatthiasG
Issue solved.
