ooCHUMoo
Jan 17, 2021Aspirant
ReadyNAS 424 XRAID Not Expanding
I was running 4x10TB (XRAID/RAID 5). I replaced two disk with 14TB so that the configuration is 2x10TB and 2x14TB. Resync completed, but volume size is the same as before installing the larger disk...
Jan 17, 2021Guru - Experienced User
Can you download the log zip file, and then post mdstat.log here?
Copy/paste it - don't try to attach it.
- ooCHUMooJan 17, 2021Aspirant
Here's mdstat.log:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md1 : active raid10 sde2[3] sdc2[2] sdb2[1] sda2[0]
1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
md127 : active raid5 sde3[5] sda3[4] sdb3[6] sdc3[1]
29284761408 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md0 : active raid1 sde1[5] sdb1[6] sda1[4] sdc1[1]
4190208 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Thu Apr 19 04:49:57 2018
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistentUpdate Time : Sun Jan 17 16:16:18 2021
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0Consistency Policy : unknown
Name : 0a440448:0 (local to host 0a440448)
UUID : 05b40dd7:f367115f:7dcea494:58ec9efd
Events : 1138Number Major Minor RaidDevice State
6 8 17 0 active sync /dev/sdb1
1 8 33 1 active sync /dev/sdc1
5 8 65 2 active sync /dev/sde1
4 8 1 3 active sync /dev/sda1
/dev/md/Data-0:
Version : 1.2
Creation Time : Sat Apr 21 09:39:45 2018
Raid Level : raid5
Array Size : 29284761408 (27928.12 GiB 29987.60 GB)
Used Dev Size : 9761587136 (9309.37 GiB 9995.87 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistentUpdate Time : Sun Jan 17 04:22:13 2021
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0Layout : left-symmetric
Chunk Size : 64KConsistency Policy : unknown
Name : 0a440448:Data-0 (local to host 0a440448)
UUID : 479170a6:4dfb3551:bbcb61e9:c0019d9b
Events : 53012Number Major Minor RaidDevice State
5 8 67 0 active sync /dev/sde3
1 8 35 1 active sync /dev/sdc3
6 8 19 2 active sync /dev/sdb3
4 8 3 3 active sync /dev/sda3- SandsharkJan 18, 2021Sensei
Is XRAID turned on (shows green stripe)? If it's not, you'll get the result you have until you manually expand the volume. But, you should be able to just turn it on and have it expand.
If it's already on, partitions.log may also be helpful.
- ooCHUMooJan 18, 2021Aspirant
Yes, green stripe under XRAID so it's on. Furthermore, if I click on it, it asks if I want to turn off XRAID and switch to FLEXRAID.
If it matters, the drive/slot configuration is 14/10/14/10. I replaced the 3rd drive initially, and then the 1st drive.
Here's partitions.log:
major minor #blocks name
8 0 9766436864 sda
8 1 4194304 sda1
8 2 524288 sda2
8 3 9761718216 sda3
8 16 13672382464 sdb
8 17 4194304 sdb1
8 18 524288 sdb2
8 19 9761718216 sdb3
8 32 9766436864 sdc
8 33 4194304 sdc1
8 34 524288 sdc2
8 35 9761718216 sdc3
8 96 4883770583 sdg
8 97 131072 sdg1
8 98 4883638272 sdg2
9 0 4190208 md0
9 127 29284761408 md127
251 0 29284759360 dm-0
8 64 13672382464 sde
8 65 4194304 sde1
8 66 524288 sde2
8 67 9761718216 sde3
9 1 1044480 md1
