petrus1956
Jan 30, 2021Follower
ReadyNAS 4312S max disk capacity
The product can use the new 16tb sata disks ? /seagate EXOS x16
Feb 03, 2021Guru - Experienced User
Netgear's HCL ( https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List ) ways that the IronWolf Pro ST16000NE000 and the Toshiba MG08ACA16TE will work.
The EXOS x16 will likely also work fine. Just make sure you get a SATA model, not SAS.
