richardhgould
Aug 20, 2011Aspirant
ReadyNAS 4TB Slow Write Performance
Config Info: Network: Router- Netgear WNDR3700 Switch- NA PC Config: Gateway FX4710-UB802A CPU Intel Q9300@2.5GHz RAM- 8GB OS: Windows Vista Home Premium 64Bit Service PAck 2 ...
mdgm-ntgr
Aug 27, 2011NETGEAR Employee Retired
Diagnostics is run on boot. Not sure if the memory is tested regularly, but the hard disks are tested daily at 4am.
I guess it'd be too late to return the unit as faulty to your reseller in exchange for a new one? If it is too late for that then contact NetGear tech support (http://www.readynas.com/support) and they should be able to arrange an RMA.
