richardhgould
Aug 20, 2011Aspirant
ReadyNAS 4TB Slow Write Performance
Config Info: Network: Router- Netgear WNDR3700 Switch- NA PC Config: Gateway FX4710-UB802A CPU Intel Q9300@2.5GHz RAM- 8GB OS: Windows Vista Home Premium 64Bit Service PAck 2 ...
CreAx
Aug 29, 2011Aspirant
is there anything new in this case ?
because i brought a DUO last week, and i see moreless the same read/write speed as you..
But not sure how you check diagnostics ?
and when i search the forums, i most say, it sounds like its the FW there is something wrong with - my friend has the same problem with his duo.. and its same FW 4.1.7
