richardhgould
Aug 20, 2011Aspirant
ReadyNAS 4TB Slow Write Performance
Config Info: Network: Router- Netgear WNDR3700 Switch- NA PC Config: Gateway FX4710-UB802A CPU Intel Q9300@2.5GHz RAM- 8GB OS: Windows Vista Home Premium 64Bit Service PAck 2 ...
richardhgould
Sep 02, 2011Aspirant
Tech support said the unit needed to be replaced. Gave me an RMA and are sending a replacement.
Not sure if it has anything to do with the slow write speed, but I will update after I replace it and measure performance.
