chemyriad
Sep 21, 2016Aspirant
readynas 516 compatibility 15k rpm and 10k rpm
does 516 model support 10k or 15k rpm drives if yes please post link to the hdds
- Sep 23, 2016
Is there a reason why? You're speed is going to be limited by the Giabit port more then the speed of the HDD. Maybe if you had a 10Gbit Network port speed would matter more so. Heat is more of a enemy I think and faster HDD produce more heat and require more power. Then you could have 6 of them all being cooled by a single fan in a small compact case. Trying to get your data through a gigabit connection. You're trying to suck your data through a straw that may need a 6" pipe. To me it doesn't make a whole lot of sense. I'm using 4 WD Red drives, the Speed is around 5400 RPM, and 2 Seagate NAS drives that are 5900 RPM, I have the two Gigabit ports plugged into my Managed 24-port Gigabit switch and have them Bonded using LACP 2+3. I can already pretty much max my network connection to my Modified 516.
So I'm not sure what you're trying to accomlish with 10K or 15K drives in it? It can't go any faster then your Network connection limitation. To me it sounds like you have the wrong NAS for your needs. Maybe a ReadyNAS 716 or better. Something with a 10Gigabit connection. That includes your switch, and to your computer. Not exacly cheap, but if you have money to spend on fast HDD's like that and want speed, a gigabit connection is not going to cut it.
It's also more then likey why they arn't tested and posted on their HDD compatibility list. You can try it and see if it works, but again, what's the point? I was looking at the HDD from Newegg. A 2,5" drive in a cooling frame around it. $314 for 1TB? Why? You can get a WD RED 6TB drive for about $274 from newegg right now. 6 times the storage for cheaper, runs cooler, is for a NAS, and can still keepup over a Gigabit Network connection. I have a couple 3TB ones in my NAS that are over 4 years old now. I pulled them from my older ReadyNAS and put them into my 516.
Sep 21, 2016Guru - Experienced User
I don't know if Netgear tested any of these drives, but the Hardware Compatibility List is here - http://kb.netgear.com/app/answers/detail/a_id/20641/~/readynas-hard-disk-compatibility-list
SATA drives not on the list often work, but Netgear can and will deny support if you use them.
Personally I'll be looking at SSDs instead (though that likely also means straying from the HCL).
- chemyriadSep 21, 2016Aspirant
i looked thru the compatibility list but doesnt have a rpm coloumn.iam now checking induvidual models one by one.if anybody have prior experience with these drives it will be helpful
- mdgm-ntgrSep 21, 2016NETGEAR Employee Retired
We don't support SAS disks in the ReadyNAS. You'll need to use HDDs/SSDs with a SATA interface.
ok .but i was referring to sata drives with 10k rpm like http://www.newegg.com/Product/Product.aspx?Item=N82E16822236243 this one
