JerryTheSpinner
May 03, 2017Follower
ReadyNAS 516 says Volume data is degraded"
Model ReadyNAS 516S Firmware: 6.4.2 Sata Drives: 6 X 4TB SATA Drives: Model WDC WP4OEFRX-68WTONO I am getting the following message in my Log - Volume: Volume data is Degraded. When I check t...
May 03, 2017Guru - Experienced User
Download the log zip file from the log screen in the web UI.
Are you seeing any signs of trouble in the on-screen logs? Also, have you looked at the SMART stats?
If you don't have an up-to-date backup you should make one.
