JeffB101
Sep 21, 2024Aspirant
ReadyNAS 516 Stops on Booting
We have a ReadyNAS 516. It is probably 8+ years old, and I believe it's running RIAD 5 with 3 hard disks. (It's been a while since I had set it up.) Several months ago, after being shut down for a...
Sep 21, 2024Guru - Experienced User
JeffB101 wrote:
Several months ago, after being shut down for a few weeks, I went to turn it back online, and the volumes were gone. I was able to access the GUI; a few screenshots are below. The error stated, "Remove inactive volumes to use the disk. Disk #1"
Do you have a backup of the files?
Just replacing a bad disk isn't enough to remount a failed volume. Download the full log zip file from the web ui, there is a lot more information in the logs on what has gone wrong.
If you need help interpreting the logs, you can send me a private message (PM) using the envelope icon in the upper right of the forum page. Put the entire log zip into cloud storage (Dropbox, google drive, etc), and put a link in the PM. Make sure the link permissions are set so anyone with the link can download.
JeffB101
Sorry, answer to your first question. I ran backups to an external drive. However, it did not back up the most important files (the family photos) for some reason...
- StephenBSep 21, 2024Guru - Experienced User
Unfortunately you have two failed drives - I gave you more details in the PM I sent you.
