kevcompton
Sep 08, 2015Apprentice
ReadyNAS 516 with EDA500 Expansion unit issue when started from timer.
Hi, When the ReadyNAS 516 and EDA500 is automatically started from a set timer sometimes but not always, the follow messages are output and the share on the EDA500 is unavailable: Disk in channe...
JennC
Sep 11, 2015NETGEAR Employee Retired
Hello kevcompton,
The RESYNC to ONLINE messages I believe is normal.
Since you mentioned there is/are share/s that is unavailable, does this mean you have multiple volumes? What's the RAID level?
kevcompton
Sep 11, 2015Apprentice
Hi,
Thanks for responding, i've added screen shots of when EDA1 is successful mounted. When not, the eda1 volume is shown in red and the only option from that screen is to format the drives. As I said, a reboot fixes this. Since posting, I have had 1 occasion where the eda1 volume is unavailable after a manual boot.
Also, I only get the RESYNC to ONLINE messages when there is an issue.
Hope you can help.
Will add a screen shot when it fails again if that helps.
Kevin.
- mdgm-ntgrSep 13, 2015NETGEAR Employee Retired
Which firmware are you running?
- JennCSep 15, 2015NETGEAR Employee Retired
Hello kevcompton,
I checked your profile and found that you have several legacy ReadyNAS units. This ReadyNAS 516 is not yet registered, this should have free support.
I think your case is for L3 escalation, please contact support center.
- kevcomptonSep 16, 2015Apprentice
Thanks.
I recently updated the firmware to the latest beta and the issue hasn't happened again.
If it does, I will contact support.
- JennCSep 17, 2015NETGEAR Employee Retired
Hello kevcompton,
In case BETA resolves the issue, please let us know. You may also post it at ReadyNAS OS6 BETA release board.
