kopi85's avatar
kopi85
readynas 516 with liquid cooling
is it possible to place an cpu liquid cooling on the readynas 516 cpu?
  • Thanks, i will look for other way to cool down the unit, ,while transcoding mkv 1080p files
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    I don't know, but even if it works this would be unsupported and would void the warranty.
    • JennC's avatar
      JennC
      Hello kopi85,
      Welcome to the community!
      As mentioned by mdgm, changing/adding internal components will void the warranty.
      Limited Liability Warranty
      NETGEAR products are covered by a limited liability warranty from defects in material and workmanship. This warranty does not apply if, in the judgement of NETGEAR, the product fails due to damage from shipment, handling, storage, accident, abuse or misuse, or if it has been used or maintained in a manner not conforming to the product's instructions, has been modified in any way, or has a defaced or removed serial number. Repair by anyone other than NETGEAR or an approved agent voids this warranty. The maximum liability of NETGEAR is the product purchase price. For details, refer to the warranty and owner registration card. You can find if your product is covered by NETGEAR warranty by comparing the duration of the warranty against the purchase date.
      • kopi85's avatar
        kopi85
  • StephenB's avatar
    Why are you asking?  What CPU temps are you seeing now?
ProSupport for Business
