ryankoenigdsi
Feb 13, 2018Aspirant
Readynas 526X - Mapped drive slow to connect then works fine
Model: ReadyNAS 526X Firmware: 6.9.2 Windows Server 2016 with Windows 7 and 10 workstations Issue: I have the ReadyNAS mapped to a drive through a GP, and all users have a long initial connecti...
ryankoenigdsi
Feb 14, 2018Aspirant
Just using it as a file share, no services or apps running from the ReadyNAS.
We have ~20 people with it mapped.
mdgm-ntgr
Feb 14, 2018NETGEAR Employee Retired
Is the NAS in the same workgroup / domain as your workstations?
- ryankoenigdsiFeb 15, 2018Aspirant
It was just "plug and play"ed on installation. Would this be causing the lag at start, where the user is trying to get authentication to the NAS? Where would these settings be to check this?
Thanks for your help
- ryankoenigdsiFeb 22, 2018Aspirant
Just following up on this. Where would these settings be, to check?
Thanks,
Ryan
- StephenBFeb 23, 2018Guru - Experienced User
On the NAS it is under accounts->authentication in the web ui.
On a Windows PC, right click on "This PC" or "My Computer" and select properties.
