Shadowlore's avatar
May 25, 2019
ReadyNas 526X "Data: dead"?
ReadyNAS 526x Firmware: 6.9.4 Hotfix 1 (will update to latest version once all this is sorted, or I'm happily convinced I'm not going to have to do a factory default. 6 drives, all WD Reds, in X-...
  • Shadowlore's avatar
    Shadowlore
    May 27, 2019
    Wow... So I finally got ahold of tech support, and Rene with tech support got the issue sorted out.
    They actually discovered another issue with the unit.. here's the full info:
    "There was some disputes on the superblock of /dev/sda so we adjusted it to sync with the other working drives. However /dev/sdb has not synced fully so I suggested to remove it from the array. Try to format /dev/sdb and hotplug it to the unit to sync again properly. Once you sync the new formatted drive, the array will be complete again and should not be degraded anymore."
    Holy. Cow. My weekend is saved.
    Now, then... to start this backup, before I issue a resync. :)
ProSupport for Business
