steveoelliott
Dec 02, 2016Luminary
ReadyNAS 526X Unmount USB drive from front panel
Hi all, On the ReadyNAS 526X is there a way to cleanly unmount a USB volume from the front panel? I am yet to actually try this so it may be self explanatory but I can't see it documented anywher...
- Dec 02, 2016
steveoelliott wrote:
On the ReadyNAS 526X is there a way to cleanly unmount a USB volume from the front panel? I am yet to actually try this so it may be self explanatory but I can't see it documented anywhere. I'd like to be able to do this to avoid bringing up the GUI to unmount the volume.
Unfortunately not, but it's a good idea.
Maybe add it to the idea exchange?
Dec 02, 2016Guru - Experienced User
steveoelliott
Will do!
