cram501
May 05, 2017Aspirant
ReadyNAS 6.7.1 failed and slow copies of large file sets
My system was updated to ReadyNAS 6.7.1 today. Ever since the upgrade, copying files to the ReadyNAS are slow and often fail. Small file sets are fine < 1GB although copies tend to slow down dram...
Retired_Member
May 05, 2017Please disable antivirus service and restart to see an improvement hopefully.
cram501
May 06, 2017Aspirant
I don't have anti-virus running . I don't have any external apps running. This is a very simple setup.
I have also rebooted it twice after the update.
- mdgm-ntgrMay 06, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- cram501May 06, 2017Aspirant
The logs have been sent.
- cram501May 10, 2017Aspirant
I sent the logs in a few days ago. Functionality since the firmware update has been very poor.
On the admin web page, large file uploads usually don't work (lots of files of 1.5+ GB). I get a communication error with about 5-10% of the files left. Transmission wasn't very fast.
Access via SMB works at about 50-100kps. All file transfers are really slow.
I'll try nfs next to see if that has any impact.
Anything else
