CarlEdman
May 13, 2017Luminary
ReadyNAS 6.7 on Legacy Hardware?
I've been running ReadyNAS 6 on my much upgraded Ultra 6 Plus for the longest time without issue. Previously when a new release came around, it would dutifully autoupgrade all the way to 6.6. Howev...
- May 15, 2017
Ok, manual update performed and quick scan of all the dashboard screens reveals no obvious problems.
vandermerwe
May 13, 2017Master
I am running 6.7.1 on an Ultra 6 plus.
It works fine, the only issue I am having, and this may not be related to the OS, is that whenever I activate ReadyDR and use it, it seems to lead to filesystem corruption and a forced read only state that I can only fix with a factory reset. This did not happen on 6.6.
I've looked for other causes without finding one.
I wouldn't hesitate to upgrade, perhaps if you are using readyDR make sure any primary data is backed up.
