IFoundTheLight
Mar 18, 2015Aspirant
ReadyNAS 600 - stuck booting (SOLVED)
My ReadyNAS 600 Rev A is stuck booting, all drives show up as green in RAIDar, no yellow lights in the front. Power light(blue) blinking every 4. I left it on for 14 hours and it got no where. This pr...
2Nutz
Mar 19, 2015Aspirant
IFoundTheLight wrote: As extra Information this seems to be a Rev A Readynas 600
http://www.readynas.com/download/docume ... S-LEDA.pdf - Best Light Language I could find
I'm going to disconnect all SATA drives and reconnect using all new SATA cables.
I don't believe the Rev. A units play nice when trying the USB reinstall method. Search throug the forums. The good news is you should have a CF card which is easy to write. It may even be the source of your problem.
If all disks check out good first, then you may want to consider getting a CF card (Its a 64mb originally but use a 128mb for extra blocks if needed). Write the correct image to the card and replace your original. By not writing to your original, you still have that as a back-up if good/needed.
Just a thought.
