IFoundTheLight
Mar 18, 2015Aspirant
ReadyNAS 600 - stuck booting (SOLVED)
My ReadyNAS 600 Rev A is stuck booting, all drives show up as green in RAIDar, no yellow lights in the front. Power light(blue) blinking every 4. I left it on for 14 hours and it got no where. This pr...
mdgm-ntgr
Apr 20, 2015NETGEAR Employee Retired
1. The file to rawrite to a CF card is the standard firmware image. If you unzip the download you should see a file called something like RAIDiator-4.1.14. This is the file you need to use.
2. For USB Boot Recovery only you need to use this. http://www.readynas.com/download/support/ReadyNAS_USB_Flash_Recovery-4.1.14.img
