Deal
Jun 01, 2025Tutor
ReadyNAS 626X spare power supply
This is a request for information: where I might buy a spare replacement power supply for my 626X. My ReadyNAS just went out of warranty and I am late getting this done. I want to buy a new power...
- Jun 05, 2025
Thanks for the tips!
Maybe I got lucky. I found a seller (Vanda Trading) on eBay with a 270W PS (item 156660240090) that has the exact pin out as the PDF diagram — pin 12 (blue) -12V and pin 18 (white) -5V have been modified to (yellow) +12V, and the listing indicates the PS is suitable for the 626X and 516 among many other Netgear NAS models. I wonder if this is one of the ones you indicated that won’t work because of the 4 pin connector?
Deal
Jun 02, 2025Tutor
The note in the PDF says this:
ReadyNAS 600, X6 and 1000S use standard ATX power connector
ReadyNAS NV, NV+ and 1100 use modified ATX power connector:
–12V(Blue) and –5V(White) changed to +12V(Yellow)
I'm not sure if the 626X is covered by either statement, but if it is, I'd guess either the 600 or X6. So the ReadyNAS 600 (and 626X??) uses a standard ATX power connector.
Not sure if you made a typo or I am misunderstanding the post/PDF.
In any case, thanks for the info.
David
