XtheUnknown
Mar 26, 2025Apprentice
ReadyNAS 626X stuck as "NETGEAR Storage Welcome" message
Well, as it says in the title. Cannot get into the boot menu with the "paperclip" approach nor the USB recovery by holding down the OK button. Power supply seems OK, fan is running and the ba...
Sandshark
Mar 26, 2025Sensei
Does the fan calm down, or stay at full speed? Do you see any activity in the LAN LED?
There are a number of things that can cause this. The simplest is that the flash has become corrupt and a USB recover will get you going. Something on one of the power busses might also be at fault. That's repairable only if it's the supply itself, which is unlikely given the age of a 626X. If Netgear would release schematics, more would be repairable, but they have not.
I have a 428 I took in trade that acts very similarly. I thought maybe I could fix it, but only valued it as a parts unit. It has a dead short on the 3.3V rail I have been unable to find. It's likely a capacitor, but I've not figured out which one. So, that's your worst-case scenario.
If you aren't actually using the 10G Ethernet, then there are a lot of units you could replace this with -- all used, of course. But if you really need 10G, your pickings are going to be slim unless you are up for a small project. A 10G Intel NIC can be made to work in a 516.
XtheUnknown
The fan stays at a constant (balanced?) speed.
I'm not using the 10G LAN, the 1G LAN port flashes green (approx 1Hz).
I've followed the published Netgear recovery steps, i.e. powering on with the USB drive in the front socket, waiting for the function buttion lights to go out and then holding the OK button in for c. 30s. The activity LED on the USB drive does NOT start to flash, which would indicate that it's not getting as far as reading the USB drive.
- XtheUnknownMar 26, 2025Apprentice
...and I've only got a fairly basic multimeter - which will be useless unless I know what voltage I should expect to find on any given pin or track (difficult without schematics, as you note), even supposing I can get the probe onto the PCB while the unit is on power.
- SandsharkMar 27, 2025Sensei
If the access LED on the flash drive doesn't even blip on, then it sounds like the unit is not getting past POST. Your next best step is to utilize the console (aka UART) port to view what's happening during boot. See here: Micro-USB-UART-Hardware.
