RN716x
Jan 04, 2023Aspirant
ReadyNAS 716X data- Two volumes after Resync
System: Readynas 716X F/W: 6.10.8 Old HDDs: 6TBx6 (WD Red) New HDD: 8TBx1 (WD Red) Raid 5 (X-Raid) I have recently experienced some issues with my Readynas system. I found out that I had to r...
- Jan 06, 2023
RN716x wrote:
Is it asking for an input here?
root@MaQBaLiNAS:~# cat /etc/mdadm/mdadm.conf
CREATE owner=root group=disk mode=0660 auto=yes
This is the same as the file on my system, so nothing unusual here.
RN716x wrote:
root@MaQBaLiNAS:~# mdadm --assemble --scan --force
mdadm: NOT forcing event count in /dev/sdc3(3) from 11031 up to 19055
mdadm: You can use --really-force to do that (DANGEROUS)
mdadm: /dev/md/data-0 assembled from 4 drives - not enough to start the array.
mdadm: No arrays found in config file or automaticallyThis is telling you that /dev/sdc3 is missing a lot of writes - so it is seriously behind the other drives in the array.
- You could proceed with --really-force instead of force. You could end up with a lot of data loss/corruption if you do that.
- Another other option is go back to SDA. Power down, remove SDC, insert the SDA. Power up, and try the same mdadm command again, and see if the event count gap is smaller. If you go this route, you should definitely mount the volume as read-only - as we know that SDA is failing, and writes will likely only accelerate that. Also they would increase the event gap between sdc and the rest of the array (making going back to SDC even more risky).
This isn't an obvious decision. SDA likely will have a smaller event gap, but we already know it has unreadable sectors. Plus it might fail when you try to offload data. Still, I think it is likely the best path (with read-only mounting).
A variant of (2) is to clone SDA, and insert the clone. The cloning process will skip over any unreadable sectors on the original. The benefit of the variant is that there will be no bad sectors detected on the clone (which is a mixed blessing, as bad sectors do give you some information on file corruption). The risk is that the original will completely fail during the cloning process.
Either way (1, 2, or 2 variant), you'd copy off as much data as you can, do a factory default with the two new drives installed in place of SDA and SDC. You'd reconfigure the NAS at that point, and then restore the files from the backup.
Jan 04, 2023Guru - Experienced User
Do you have any log zip files - either after the first resync, or after the reboot? Maybe also download one now if you can.
RN716x
- RN716xJan 04, 2023Aspirant
So follwoing what Sandshark has said, I am now able to see that the SSH service is enabled by default. I left it there for now, hoping to get some tips on how to proceed further.
- StephenBJan 04, 2023Guru - Experienced User
It's not enabled by default, but however it happened, it is enabled.
The log zip is for some reason missing most of the files. It looks like it is from 12/20.
The problem is that the resync of the new 8 TB disk failed due to disk errors on disk sda (in the first slot):
Dec 20 03:36:33 MaQBaLiNAS mdadm[3964]: Fail event detected on md device /dev/md127, component device /dev/sda3Dec 20 03:36:02 MaQBaLiNAS kernel: blk_update_request: I/O error, dev sda, sector 11233252792 Dec 20 03:36:02 MaQBaLiNAS kernel: md/raid:md127: read error not correctable (sector 11223815544 on sda3). Dec 20 03:36:02 MaQBaLiNAS kernel: md/raid:md127: read error not correctable (sector 11223815552 on sda3). Dec 20 03:36:02 MaQBaLiNAS kernel: md/raid:md127: read error not correctable (sector 11223815560 on sda3). Dec 20 03:36:02 MaQBaLiNAS kernel: md/raid:md127: read error not correctable (sector 11223815568 on sda3). Dec 20 03:36:02 MaQBaLiNAS kernel: md/raid:md127: read error not correctable (sector 11223815576 on sda3). Dec 20 03:36:02 MaQBaLiNAS kernel: md/raid:md127: read error not correctable (sector 11223815584 on sda3). Dec 20 03:36:02 MaQBaLiNAS kernel: md/raid:md127: read error not correctable (sector 11223815592 on sda3). Dec 20 03:36:02 MaQBaLiNAS kernel: md/raid:md127: read error not correctable (sector 11223815600 on sda3). Dec 20 03:36:02 MaQBaLiNAS kernel: md/raid:md127: read error not correctable (sector 11223815608 on sda3). Dec 20 03:36:02 MaQBaLiNAS kernel: md/raid:md127: read error not correctable (sector 11223815616 on sda3).There are several more of the uncorrectable errors after this (look in systemd-journal.log).
One option is to try cloning either disk 1 (sda) or the original sdd to a new drive. Not sure which is better. Then you could forcibly assemble the array, and ideally offload data before preceeding. There likely would be some data loss (since there are errors on sda, and sdd also clearly had issues).
You could also try RAID recovery software - though you'd need to be able to connect the drives to a Windows PC (getting a suitable USB enclosure), and software like ReclaiMe is also pricey. Plus you'd need storage to offload the data that is recovered.
- RN716xJan 04, 2023AspirantIf the original sdd (6TB) is still working in the pre-sync state. i.e. I removed it and replaced it with the new 8TB. Would I still need to clone it to a new drive or can I just connect it and try to assemble?
What difference would cloning make then?
For the sda (6TB), the plan was to replace it when the sdd is resynced successfully with a new 8TB that I've also got ready that I might use for cloning either now.
I'm trying to weigh my options here, would re-connecting the original sdd (6TB) help here while maybe isolating sda just to take a backup first? It should be in the pre-sync state.
Would you elaborate further on this part please, just to make sure I'm following correctly:
"Then you could forcibly assemble the array,"
