RN716x
Jan 04, 2023Aspirant
ReadyNAS 716X data- Two volumes after Resync
System: Readynas 716X F/W: 6.10.8 Old HDDs: 6TBx6 (WD Red) New HDD: 8TBx1 (WD Red) Raid 5 (X-Raid) I have recently experienced some issues with my Readynas system. I found out that I had to r...
- Jan 06, 2023
RN716x wrote:
Is it asking for an input here?
root@MaQBaLiNAS:~# cat /etc/mdadm/mdadm.conf
CREATE owner=root group=disk mode=0660 auto=yes
This is the same as the file on my system, so nothing unusual here.
RN716x wrote:
root@MaQBaLiNAS:~# mdadm --assemble --scan --force
mdadm: NOT forcing event count in /dev/sdc3(3) from 11031 up to 19055
mdadm: You can use --really-force to do that (DANGEROUS)
mdadm: /dev/md/data-0 assembled from 4 drives - not enough to start the array.
mdadm: No arrays found in config file or automaticallyThis is telling you that /dev/sdc3 is missing a lot of writes - so it is seriously behind the other drives in the array.
- You could proceed with --really-force instead of force. You could end up with a lot of data loss/corruption if you do that.
- Another other option is go back to SDA. Power down, remove SDC, insert the SDA. Power up, and try the same mdadm command again, and see if the event count gap is smaller. If you go this route, you should definitely mount the volume as read-only - as we know that SDA is failing, and writes will likely only accelerate that. Also they would increase the event gap between sdc and the rest of the array (making going back to SDC even more risky).
This isn't an obvious decision. SDA likely will have a smaller event gap, but we already know it has unreadable sectors. Plus it might fail when you try to offload data. Still, I think it is likely the best path (with read-only mounting).
A variant of (2) is to clone SDA, and insert the clone. The cloning process will skip over any unreadable sectors on the original. The benefit of the variant is that there will be no bad sectors detected on the clone (which is a mixed blessing, as bad sectors do give you some information on file corruption). The risk is that the original will completely fail during the cloning process.
Either way (1, 2, or 2 variant), you'd copy off as much data as you can, do a factory default with the two new drives installed in place of SDA and SDC. You'd reconfigure the NAS at that point, and then restore the files from the backup.
RN716x
Jan 06, 2023Aspirant
StephenB wrote:Well, you didn't try the mdadm command I posted.
root@MaQBaLiNAS:~# mdadm --force --assemble /dev/md127
mdadm: --force does not set the mode, and so cannot be the first option.
StephenB wrote:
One puzzle here is the missing files in your log zip. Can you post /etc/mdadm/mdadm.conf ???
root@MaQBaLiNAS:~# /etc/mdadm/mdadm.conf
-bash: /etc/mdadm/mdadm.conf: Permission denied
StephenB wrote:
btrfs device scan
But you need to get the mdadm part to work before you try the btrfs command.
Still tried it even though,
root@MaQBaLiNAS:~# btrfs device scan
Scanning for Btrfs filesystems
Then tried this command
5 drives are connected (inc. original 6TB sdd4). The only drive not connected is the sdda. Should I try connecting sdda which failed during sync but is still working, or perhaps the sdd4 8TB which apparently didn't successfully sync?
The 'mount' command throws this output:
root@MaQBaLiNAS:~# mount /dev/md127 /data
mount: special device /dev/md127 does not exist
Jan 06, 2023Guru - Experienced User
One challenge here is sorting out how much linux people know.
You tried to execute the conf file - which can't be done. If you want to list it, you type
But there is a hint that the RAID array isn't in the config file (the error message you got when you tried to do mdadm --assemble --scan).
mdadm: /dev/md/data-0 assembled from 4 drives - not enough to start the array. mdadm: No arrays found in config file or automatically
Again, this is the step you HAVE to get resolved first. There is no point in continuing until you can force the mdadm array to assemble.
Try adding --force to this command.
FWIW, I am worried that even if you get past this you will end up needing to do a factory default - it's pretty clear from the log zip that you have more issues - not just an inactive volume. So if we can get it mounted, it will be important to offload the data to other storage.
- RN716xJan 06, 2023Aspirant
root@MaQBaLiNAS:~# cat /etc/mdadm/mdadm.conf CREATE owner=root group=disk mode=0660 auto=yesThen
root@MaQBaLiNAS:~# mdadm --assemble --scan --force mdadm: NOT forcing event count in /dev/sdc3(3) from 11031 up to 19055 mdadm: You can use --really-force to do that (DANGEROUS) mdadm: /dev/md/data-0 assembled from 4 drives - not enough to start the array. mdadm: No arrays found in config file or automatically - StephenBJan 06, 2023Guru - Experienced User
Following option 2, removed sdd, connected sda in read-only. The difference is clearly narrower.
root@MaQBaLiNAS:~# mdadm --assemble --scan --force mdadm: NOT forcing event count in /dev/sda3(0) from 18988 up to 19055 mdadm: You can use --really-force to do that (DANGEROUS) mdadm: /dev/md/data-0 assembled from 4 drives - not enough to start the array. mdadm: No arrays found in config file or automatically root@MaQBaLiNAS:~# mdadm --assemble --scan --really-force mdadm: forcing event count in /dev/sda3(0) from 18988 upto 19055 mdadm: /dev/md/data-0 assembled from 5 drives - not enough to start the array. mdadm: No arrays found in config file or automatically - RN716xJan 06, 2023Aspirant
Quick update after restarting the Nas. Not sure if trying to reconnect sdd to resync would be a good option, hoping to have better redundancy till offload the data.
I'm glad it finally mounted.
Don't add any more drives - that will start a resync process that will stress the failing one. If you push it over the edge trying to get redundancy, then you will lose all your data. Remember this whole mess started when disk errors on sda caused the resync to fail.
Just offload everything you can as quickly as you can - using what space you have now to get things started.
- StephenBJan 09, 2023Guru - Experienced User
I'm glad you got the data off. It's very nerve-wracking when multiple disks are having problems.
