stoufly
Mar 17, 2015Aspirant
ReadyNas Admin FrontView Panel Null
Hi all, I've exactly the same problem as here : http://www.readynas.com/forum/viewtopic.php?f=64&t=59085#p332153 But in a different situation. Indeed, I run my Nas Duo since 2011 with 2 WD Green...
mdgm-ntgr
Mar 17, 2015NETGEAR Employee Retired
Yes. It is definitely a v1: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
You can't install v1 firmware on a v2 and you can't do vice versa either. You are running v1 firmware so you must have a v1
After the firmware update you may find it works in your preferred browser again.
