stoufly
Mar 17, 2015Aspirant
ReadyNas Admin FrontView Panel Null
Hi all, I've exactly the same problem as here : http://www.readynas.com/forum/viewtopic.php?f=64&t=59085#p332153 But in a different situation. Indeed, I run my Nas Duo since 2011 with 2 WD Green...
WWC
Oct 21, 2015Aspirant
I am having a similar issue when I boot my NV+ V1 READYNAS diks show healthy when I try to luanch the admin page from the RAIDATOR software of directly in any web browser it loads only partially and I cannot click on anything to do anything. I booted in Tech Support mode and I am able to telnet to the NAS but do not know what to do next to see if the OS partition is full or a log file would need to be deleted any help would be greatly apprecaited as I do nopt want to have to do a factory reset as I did a lot of configuration to get this setup the way I wanted. I already tried an OS re-install as well. I am using firmware 4.1.14.
- StephenBOct 21, 2015Guru - Experienced User
Log in with ssh and enter:
df . -h
df . -i
and report the results.
- WWCOct 21, 2015Aspirant
I woyld love to do that but ssh is not installed or enabled is there a way to do this via telent in Tech Support Mode and enable or install SSH?
With telnet, you'd need to mount the OS partition, and then execute those commands from the mount point.
You should be able to find the instructions on-line if you search.
