stoufly
Mar 17, 2015Aspirant
ReadyNas Admin FrontView Panel Null
Hi all, I've exactly the same problem as here : http://www.readynas.com/forum/viewtopic.php?f=64&t=59085#p332153 But in a different situation. Indeed, I run my Nas Duo since 2011 with 2 WD Green...
Oct 21, 2015Guru - Experienced User
Log in with ssh and enter:
df . -h
df . -i
and report the results.
WWC
Oct 21, 2015Aspirant
I woyld love to do that but ssh is not installed or enabled is there a way to do this via telent in Tech Support Mode and enable or install SSH?
- StephenBOct 21, 2015Guru - Experienced User
With telnet, you'd need to mount the OS partition, and then execute those commands from the mount point.
You should be able to find the instructions on-line if you search.
- WWCOct 21, 2015Aspirant
I looked and tried nad I could not find anything.
- StephenBOct 22, 2015Guru - Experienced User
Really it isn't hard to google. These search strings bring it up right away:
telnet into readynas NV+
mount readynas OS partition tech support mode
telnet instructions
http://netgear.nas-central.org/wiki/TechSupportMode
Mount instructions are posted by chirpa on this thread: https://community.netgear.com/t5/Using-your-ReadyNAS/Readynas-NV-V1-Mounting-OS-partition-in-support-mode/td-p/894479
