Garfunkalow
Jul 22, 2015Aspirant
ReadyNAS "Admin Page" is offline, Apps still work.
Since 6.2.4 i haven't been able to connect to the admin page. readynasd.service - ReadyNAS System Daemon
Loaded: loaded (/lib/systemd/system/readynasd.service; enabled)
Active: a...
- Jul 22, 2015
Garfunkalow wrote:
Interesting. works fine in internet explorer but chrome just says that the admin page is offline. I never though i'd write a sentence like that.
IE 11.0.9600.17905
Chrome 44.0.2403.89 m
So then in your case at least it sounds like a browser compatibility issue has been introduced by a newer version of Chrome.
Garfunkalow
for what it's worth, i've read through quite a few others and they're reporting a conf which doesn't clean up when installing an app, this seems to be resolved in 6.2.3 thus doesn't affect this. but i'll dump the info from apache2 just in case
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled)
Active: active (running) since Wed, 22 Jul 2015 10:42:07 -0600; 1h 34min ago
Process: 1626 ExecReload=/bin/kill -USR1 $MAINPID (code=exited, status=0/SUCCESS)
Process: 1621 ExecReload=/usr/sbin/apache2 $OPTIONS -t (code=exited, status=0/SUCCESS)
Main PID: 1172 (apache2)
CGroup: name=systemd:/system/apache2.service
├ 1172 /usr/sbin/apache2 -k start
├ 1638 apache_log
├ 1639 /usr/sbin/apache2 -k start
├ 1640 /usr/sbin/apache2 -k start
├ 1641 /usr/sbin/apache2 -k start
├ 1642 /usr/sbin/apache2 -k start
├ 1643 /usr/sbin/apache2 -k start
├ 1644 /usr/sbin/apache2 -k start
├ 1766 /usr/sbin/apache2 -k start
├ 1933 /usr/sbin/apache2 -k start
├ 1970 /usr/sbin/apache2 -k start
└ 2011 /usr/sbin/apache2 -k start
Jul 22 10:51:44 GarfsNAS apache_access[1638]: 192.168.1.135 "POST /fwbroker HTT...0
Jul 22 10:51:44 GarfsNAS apache_access[1638]: 192.168.1.135 "POST /dbbroker HTT...0
Jul 22 10:51:44 GarfsNAS apache_access[1638]: 192.168.1.135 "POST /fsbroker/ HT...0
Jul 22 10:51:45 GarfsNAS apache_access[1638]: 192.168.1.135 "POST /fwbroker HTT...0
Jul 22 10:51:45 GarfsNAS apache_access[1638]: 192.168.1.135 "POST /dbbroker HTT...0
Jul 22 12:10:55 GarfsNAS apache_access[1638]: Suppressed 4 duplicate messages
Jul 22 12:10:55 GarfsNAS apache_access[1638]: 192.168.1.135 "GET /admin HTTP/1....1
Jul 22 12:10:55 GarfsNAS apache_access[1638]: 192.168.1.135 "GET /admin/ HTTP/1...0
Jul 22 12:11:09 GarfsNAS apache_access[1638]: 192.168.1.135 "GET /dbbroker?down...0I have proactively emailed the logs as well.
- BrianL2Jul 22, 2015NETGEAR Employee Retired
Hi Garfunkalow,
Yes that problem is only evident to the previous firmware. Please contact support to resolve this issue immediately.
Kind regards,
BrianL
NETGEAR Community
- mdgm-ntgrJul 22, 2015NETGEAR Employee Retired
# sqlite3 /var/readynasd/db.sq3 'pragma integrity_check;' # sqlite3 /var/readynasd/event.sq3 'pragma integrity_check;' # sqlite3 /var/readynasd/smart.sq3 'pragma integrity_check;'
- GarfunkalowJul 22, 2015Aspirant
rebooted the system thrice.
Errored the first 2 times, now can connect.
the sqlite3 commands all returned 'ok'
This keeps happening intermittently now. when i'm in an 'error' state i'll run the sqllite3 commands again and see what the results are.
happy to see quick replies from people :smileyhappy: thank-you.
