Mjar
Sep 05, 2015Aspirant
ReadyNAS "Admin Page" is offline
Hi all, Unfortunately, my ReadyNAS (OS 6.2.4) has been troubled for quite some time. I'm not able to connect to the admin page of the NAS within a couple of days after a device reset. When I rese...
- Sep 11, 2015
Hi all,
I have exchanged the standard 1GB memory with a single 2GB memory module (Mushkin Essentials - DDR3 - 2 GB - SO DIMM 204-pin - 1333 MHz / PC3-10666 - CL9 - 1.5 V - non-buffer - non-ECC) and my problems are gone. I have stressed it with quite some Transmission, Sabnzbd and Sickbeard activities at the same time which would definately result in a crash before the memory upgrade and.. admin page is working fine. Apparantly a legacy device (Readynas Ultra 2) can't always run OS6 with the same apps as OS4 without some memory issues if you're a 'heavy' user. Solution for me: 2Gb of memory instead of 1Gb. Hope this helps someone.
Mjar
Just send them in, thanks a lot for looking into this!
mdgm-ntgr
Sep 05, 2015NETGEAR Employee Retired
You are still running too much on the NAS and it is running out of memory. I can see that MySQL is one of the services you are running.
- MjarSep 05, 2015Aspirant
Thanks for your help, much appreciated! It is strange though, I have the app 'MySql Server' disabled. I currently run these apps:
- Python
- PHP
- SMB Plus
- PHPMyAdmin
- SSH
- SABnzbd
- Transmission
- Sickbeard
Is one of them too heavy on memory resources? And would upgrading from 1GB to 2GB of memory fix the memory issues?
Thanks!
- RezzZSep 06, 2015Tutor
I got the same issue Mjar, I need to disable all services to be able to reach the admin page at all. It started just before I upgraded to 6.2.4
load avarage is between 1,3 and 1,5 when completely idle but CPUs are idle. Not sure yet what is lagging the system but just like you I don't run that much that could cause this inresponsiveness.
Right now I'm only downloading with sabnzbdplus and admin page is completely unreachable.
Is there a way to reinstall only the OS for my readynas and keep my data?
- MjarSep 06, 2015Aspirant
Hmm, sounds similar indeed. I have ordered the 2 GB of memory, will find out this week if that fixes the problem. I will try your settings as well, disabling all apps and see if it crashes again. Could it be a memory leak in the admin page software or something? Since all apps are working perfectly fine.
