Mjar
Sep 05, 2015Aspirant
ReadyNAS "Admin Page" is offline
Hi all, Unfortunately, my ReadyNAS (OS 6.2.4) has been troubled for quite some time. I'm not able to connect to the admin page of the NAS within a couple of days after a device reset. When I rese...
- Sep 11, 2015
Hi all,
I have exchanged the standard 1GB memory with a single 2GB memory module (Mushkin Essentials - DDR3 - 2 GB - SO DIMM 204-pin - 1333 MHz / PC3-10666 - CL9 - 1.5 V - non-buffer - non-ECC) and my problems are gone. I have stressed it with quite some Transmission, Sabnzbd and Sickbeard activities at the same time which would definately result in a crash before the memory upgrade and.. admin page is working fine. Apparantly a legacy device (Readynas Ultra 2) can't always run OS6 with the same apps as OS4 without some memory issues if you're a 'heavy' user. Solution for me: 2Gb of memory instead of 1Gb. Hope this helps someone.
Mjar
Sep 06, 2015Aspirant
Hi Stephen, do you perhaps have any other suggestions on what to do? Thanks!
- StephenBSep 06, 2015Guru - Experienced User
I believe the web admin ui runs at a relatively low priority. I'd start with lowering the priority of sabnzbdplus and see if access returns.
The load average question has been here from the beginning. To some degree that depends on the application structure (since the load average is simply the number of things waiting to execute)
- RezzZSep 07, 2015Tutor
strange thing, chrome for Mac seems to have more problems with the page being offline than safari, or chrome/firefox on windows...
- SandsharkSep 10, 2015Sensei
I occasionally find it "offline" and closing the web browser tab and opening a new one fixes it. Must be a bug there somewhere, but just an annoyance.
