Mjar
Sep 05, 2015Aspirant
ReadyNAS "Admin Page" is offline
Hi all, Unfortunately, my ReadyNAS (OS 6.2.4) has been troubled for quite some time. I'm not able to connect to the admin page of the NAS within a couple of days after a device reset. When I rese...
- Sep 11, 2015
Hi all,
I have exchanged the standard 1GB memory with a single 2GB memory module (Mushkin Essentials - DDR3 - 2 GB - SO DIMM 204-pin - 1333 MHz / PC3-10666 - CL9 - 1.5 V - non-buffer - non-ECC) and my problems are gone. I have stressed it with quite some Transmission, Sabnzbd and Sickbeard activities at the same time which would definately result in a crash before the memory upgrade and.. admin page is working fine. Apparantly a legacy device (Readynas Ultra 2) can't always run OS6 with the same apps as OS4 without some memory issues if you're a 'heavy' user. Solution for me: 2Gb of memory instead of 1Gb. Hope this helps someone.
Mjar
Sep 11, 2015Aspirant
Hi all,
mdgm-ntgr
Sep 13, 2015NETGEAR Employee Retired
Well all our current x86_64 models ship with OS6 come with at least 2GB RAM. 1GB isn't the sweet spot it used to be.
As the memory in PCs that ship rises over time, apps, OSes etc. may add new features etc. and start using more memory.
6.4.0 has a new kernel and you may also see some improvements from that.
