dhw
Jul 27, 2014Aspirant
ReadyNAS as Network UPS Tools (NUT) client?
I recently replaced our aged UPS with a new APC SmartUPS XL series. It provides power for the ReadyNAS (Pioneer Pro 6), a couple of FreeBSD machines, a couple of switches, and a DSL modem. One of ...
dhw
Oct 18, 2014Aspirant
Thanks. I tried that; it appeared to "work":
howland:/etc/nut# /etc/init.d/ups-monitor restart
Restarting Network UPS Tools:.
howland:/etc/nut# echo $?
0
howland:/etc/nut#
but Front view doesn't show status. On the other hand:
howland:/etc/nut# upsc Main@172.16.8.1
battery.alarm.threshold: 0
battery.charge: 100.0
battery.charge.low: 0
battery.charge.restart: 00
(and trying to use the hostname vs. the IP address whined "Error: Connection failure: Connection refused" -- then again, the machine where the UPS is physically connected is multi-homed, so I suppose that could confuse things a bit).
So I *think* this means that "it's working," and I shouldn't get fussed about Frontview.
Thanks for your help & patience. :-)
0
howland:/etc/nut#
