NathanWoodruff's avatar
Sep 22, 2021
ReadyNas auto shutdown for no reason with eSATA
I plug in an eSATA JBOD group to do a backup of selected directorys and within 5 minutes of starting the backup, the 316 front panel shows "SHUTDOWN" and then powers off.
I crated the eSATA JBOD group with the ReadyNas 316 and all was well. But as soon as a backup start to copy files, it is only minutes before the ReadyNas does a shutdown.
What is happening?
  • A JBOD/RAID created in an eSATA chassis (Netgear EDA500 or equivalent) as a NAS volume is not intended to be connected and disconnected, especially with power applied.  While the NAS will complain about the missing volume, it does appear to be safe to remove and replace one when power is off.  But each time you re-connect, the NAS will have to re-synchronize the OS partition copy that is on the eSATA chassis drives.  Add to that the fact that the connector for eSATA is not a good choice for multiple mates and demates, and you are flirting with disaster if you do remove and replace often.
    I suspect your shut-down is related to the OS partition re-sync, but I don't have hard evidence.  I just know that's something unique that's going to happen in that first five minutes.
    My experience with multi-drive eSATA chassis on a ReadyNAS is that it was a very bad idea from the start and I fully understand why Netgear discontinued the EDA500.
    • NathanWoodruff's avatar
      NathanWoodruff
      I leave the eSATA chassis on plugged in and connected the entire time. But as soon as I go to copy directories from the NAS drives, within minutes it does a shutdown.
      Should I give up on the idea of using eSATA drives as a backup or should I instead of crating a JBOD volume of all the drives, create a single volume for each drive in the chassis? or convert them to USB connected drives instead?
      Thanks for your help.
      • Sandshark's avatar
        Sandshark
        Sensei
        OK, that's good.  I misunderstood that you meant you plugged it in only once, thinking you were doing it every time.
        Are there any entries in the system log before the shut down?  Is the shut-down itself even logged?  You may also be able to find clues in the other logs of the download log .zip file.  StephenB is better than I at pointing where to look.
        I suppose one possibility is that something is overheating.  I used the EDA500 on an RN616, and the CPU activity was high on a scrub, so I would think it would be far worse on an RN316, but I don't think a simple backup job would have a similar issue.
        I was using RAID5 on my EDA500, which means it's writing back and forth between all the drives.  That was a disaster.  In the case of JBOD, I would think it would not have as big a problem.  Just be prepared for a scrub or balance to take a while.
ProSupport for Business
