gpearson9
Aug 22, 2016Aspirant
ReadyNAS backup alert messages not showing errors
I have a backup job configured to copy files from my ReadyNAS unit to a Windows based backup server. It routinely fails on some files because some of our users are on OSX and use invalid Windows char...
BrianL2
Aug 23, 2016NETGEAR Employee Retired
Hi gpearson9,
Have you downloaded the logs that's in a zip format? You can check the backup copy log to know which files were and weren't copied on your backup job.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
- gpearson9Aug 26, 2016Aspirant
Yeah that is what I usually do to find the files that failed. I was just wondering if it was possible to get the failed files to appear directly in the error email like the successfully copied files do. It is much easier to inform non-IT personel of an issue with a file they created by forwarding an email instead of having to dig into the logs and copy/paste the list.
