Arnav
May 23, 2017Aspirant
Readynas Backups and snapsots
I have been using my readynas for 3 months now. I am using snapshots to backup my data and have now finally had the time to set up automated backups to a USB to take offsite. I have come up with th...
capaz
May 24, 2017Tutor
jak0lantash wrote:
Arnav wrote:The auto backup only allows you to select one folder to backup. You can't pick a folder within the tree of folders not to backup.
Is "auto backup" something specific?
Because I'm able to select a subfolder with no difficulty from the "new backup job" wizard:
I assumed that he meant, for example, that you can't multi-select, i.e., at a given level, select all folders *except* the one(s) you want to avoid. In your screenshot, suppose, instead of folder, there were folder1, folder2, and folder3. If you wanted to skip folder2, you couldn't multi-select folder1 and folder3.
jak0lantash
May 24, 2017Mentor
Mmmm OK. He said "a folder", but if that's what he meants, then indeed, you can't do that directly. Either you create several backup jobs (one per subfolder) or you use rsync backup job with exclusions (which can be tricky because your exclude by name, not path, so an object further down the tree may match the exclusion too).
