jhyland
Oct 20, 2015Tutor
ReadyNAS becomes unresponsive - could it be tied to FW6.4 and backups?
I own a ReadyNAS 104. I currently have four 3TB drives in it in X-Raid. (5.86TB free of 8.17TB total). I have a 5TB USB 3.0 drive plugged into the front USB Drive. It is formatted as EXT4. I am ...
Sgt_Torpedo
Dec 24, 2015Aspirant
I have a RN104 with 2 3TB drives and it becomes unresponsive during a network backup to a Western Digital EX2 3TB NAS. It also is unresponsive during a backup operation from a Windows 10 Pro using the MS Windows 7 software. My conclusion is that during a heavy load, the RN104 just ignores incoming requests. I have not done any real troubleshooting since I just closed a support ticket when the FW update to 6.4 lost the RAID volume. (Netgear support was able to recover the volume.)
Is this an issue being addressed in the next FW release? If it is and is coming SOON, I will patiently wait. If not, it will be another thing on my list of reasons to steer people away from ReadyNAS units.
Thanks for the help.
Dec 24, 2015Guru - Experienced User
There is one RAID stability fix in 6.4.2 beta - might be worth a try.
- Sgt_TorpedoDec 24, 2015Aspirant
The bug fix list looks like it may adderss the issue, but I will wait until I dont need to downgrade the FW before I upgrade it. I am using FW 6.4.1 and just recovered from a major error when the unit lost the RAID volume.
Thanks
WARNINGS:
- Devices updated with 6.4.2 BETA firmware cannot be downgraded to versions of the firmware earlier than 6.4.0.
- ReadyNAS 102, 104, and 2120 must not be updated directly from 6.3.0 - 6.3.4 to 6.4.x. They must first be updated to either 6.2.x or 6.3.5.
- StephenBDec 24, 2015Guru - Experienced User
Thanks
WARNINGS:
You must be misunderstanding the warnings. You can directly install 6.4.2 beta on a 6.4.1 system (I did it myself yesterday).
If you want to switch back to 6.4.1, you can easily downgrade - just manually install 6.4.1 from the web ui.
I will give it a try later tonight or tomorrow.
Thanks
