jhyland
Oct 20, 2015Tutor
ReadyNAS becomes unresponsive - could it be tied to FW6.4 and backups?
I own a ReadyNAS 104. I currently have four 3TB drives in it in X-Raid. (5.86TB free of 8.17TB total). I have a 5TB USB 3.0 drive plugged into the front USB Drive. It is formatted as EXT4. I am ...
Dec 24, 2015Guru - Experienced User
Sgt_Torpedo wrote:
I have a RN104 with 2 3TB drives and it becomes unresponsive during a network backup to a Western Digital EX2 3TB NAS. It also is unresponsive during a backup operation from a Windows 10 Pro using the MS Windows 7 software.
There is one RAID stability fix in 6.4.2 beta - might be worth a try.
Sgt_Torpedo
Dec 24, 2015Aspirant
The bug fix list looks like it may adderss the issue, but I will wait until I dont need to downgrade the FW before I upgrade it. I am using FW 6.4.1 and just recovered from a major error when the unit lost the RAID volume.
Thanks
WARNINGS:
- Devices updated with 6.4.2 BETA firmware cannot be downgraded to versions of the firmware earlier than 6.4.0.
- ReadyNAS 102, 104, and 2120 must not be updated directly from 6.3.0 - 6.3.4 to 6.4.x. They must first be updated to either 6.2.x or 6.3.5.
- StephenBDec 24, 2015Guru - Experienced User
Thanks
WARNINGS:
You must be misunderstanding the warnings. You can directly install 6.4.2 beta on a 6.4.1 system (I did it myself yesterday).
If you want to switch back to 6.4.1, you can easily downgrade - just manually install 6.4.1 from the web ui.
- Sgt_TorpedoDec 24, 2015Aspirant
I will give it a try later tonight or tomorrow.
Thanks
