jhyland
Oct 20, 2015Tutor
ReadyNAS becomes unresponsive - could it be tied to FW6.4 and backups?
I own a ReadyNAS 104. I currently have four 3TB drives in it in X-Raid. (5.86TB free of 8.17TB total). I have a 5TB USB 3.0 drive plugged into the front USB Drive. It is formatted as EXT4. I am ...
BrianL2
Oct 20, 2015NETGEAR Employee Retired
Hi jhyland,
Welcome to the community!
Can you confirm if your backups are pointed to the external USB device plugged in to your NAS? If you will disconnect it, will it still freeze or lockup while you're using it? I also suggest to check if both disk spin down and power timer feature are enabled, have them disabled and see if the behavior continues.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
- jhylandOct 21, 2015TutorHi Brian,Yes, my backups are pointed to the external USB device plugged into my NAS. I just tried to access from my windows machine a share to the external USB device plugged into my NAS and it caused the unit to lock-up. I have not tried disconnecting the external USB drive yet.So a common thread seems to be when the external USB drive is being accessed through/from the NAS it is causing it lock up. (whether from a backup job or from a share). Note that a very small backup job that may not have any files to backup that day does not cause the unit to lock up.Hope this info helps.Thanks.
- BrianL2Oct 21, 2015NETGEAR Employee Retired
Hi jhyland,
Thanks for the information that you have provided. Also, can you confirm if this external USB hard drive uses an external power supply?
Kind regards,
BrianL
NETGEAR Community Team- jhylandOct 21, 2015Tutor
Hi Brian,
Yes there is a separate power supply for the USB hard drive. It is a Samsung D3 Station 5TB USB 3.0 Desktop External Hard Drive. I unplugged the external hard drive, unplugged and replugged in the NAS to get it working again. I manually started the backup jobs. They all failed as I would expect since the external HD is disconnected. The NAS is still responding. The common thread still seems to be when the NAS is trying to access the external HD. As I mentioned before, I wasn't having this issue before the 6.4 upgrade. Any ideas for me to try?
Thanks for your help.
