jhyland
Oct 20, 2015Tutor
ReadyNAS becomes unresponsive - could it be tied to FW6.4 and backups?
I own a ReadyNAS 104. I currently have four 3TB drives in it in X-Raid. (5.86TB free of 8.17TB total). I have a 5TB USB 3.0 drive plugged into the front USB Drive. It is formatted as EXT4. I am ...
BrianL2
Oct 21, 2015NETGEAR Employee Retired
Hi jhyland,
Thanks for the information that you have provided. Also, can you confirm if this external USB hard drive uses an external power supply?
Kind regards,
BrianL
NETGEAR Community Team
jhyland
Oct 21, 2015Tutor
Hi Brian,
Yes there is a separate power supply for the USB hard drive. It is a Samsung D3 Station 5TB USB 3.0 Desktop External Hard Drive. I unplugged the external hard drive, unplugged and replugged in the NAS to get it working again. I manually started the backup jobs. They all failed as I would expect since the external HD is disconnected. The NAS is still responding. The common thread still seems to be when the NAS is trying to access the external HD. As I mentioned before, I wasn't having this issue before the 6.4 upgrade. Any ideas for me to try?
Thanks for your help.
- BrianL2Oct 24, 2015NETGEAR Employee Retired
Hi jhyland,
I appreciate the information that you have provided. I believe it would be better if you will contact our support team to create a ticket about this issue that you have reported.
Kind regards,
BrianL
NETGEAR Community Team- jhylandOct 28, 2015Tutor
For those that may be experiencing a similar issue: I opened a support ticket as requested. Here is the latest status:
"Your case is assign to me, As with this case and I would like to inform you that we are also trying to replicate this case in our end
We got an update form our engineering that this might be a bug on the firmware, However they are diligently working on this issue, We might need to released latest firmware soon to fix this problem. I will get back to you once I have an update myself.
We truly appreciate your patience and we will leave this case open and we will get in touch with you as soon as possible."- ScadsNov 01, 2015Aspirant
Just to make it quite clear that your problem is not an isolated occurrance. I have an RN102, backing up onto a Seagate 5TB UHB Drive. The NAS works fine on its own, but locks up immediately I restart it with the UHB Drive attached. The UHB Drive works fine in other circumstances, and had previously been a reliable backup mechanism. I can only conclude that it is the FW6.4 that is to blame. The problem occurred immediately I upgraded.
It seems to me that the advice slip on OS6.4 does not cover this, but that many may be blaming the unresponsiveness of their RN on the wrong thing.
