jonl0711
Apr 30, 2016Aspirant
ReadyNAS Bonded Ethernet
I've recently purchase the RN314 and EDA500 unit. I would like to know can I bond the ethernet ports to a ProSafe 8-port Gigabit Ethernet Switch. I have around 10 TB of images I need to copy to th...
May 01, 2016Guru - Experienced User
The GS108T supports LACP bonding. The unmanaged versions (GS108, GS108E, GS108PE) do not, and neither does the GSS108E. You can still use TLB or ALB bonding with the unmanaged switches as they don't require special switch support.
jonl0711 wrote:
In order words will bonding the ethernet ports give me 2 Gb network speed?
It might improve the speeds if you are downloading from more than one PC - especially if some are downloading to the 314 shares and others are downloadng to the EDA shares.
With LACP bonding, if you use 2 clients to do the uploading there is still a 50-50 chance that the traffic from both clients will use the same ethernet port on the RN314.
jonl0711 wrote:
I have around 10 TB of images I need to copy to the RN
Where are these images now? External USB drives? If so, are they USB 3.0? How are they formatted?
Note that if data is on USB 2.0 drives, the USB 2 speed is the bottleneck, so bonding won't speed the transfers.
jonl0711
May 23, 2016Aspirant
The data is on internal drives on a RAID 5 setup.
They are raw files from the Canon Camera (.cr2) and each file is at least 25 MB in size.
I was wondering if I should put 2 NIC oin the PC and then try teaming to the switch,.
BTW the switch has been changed to a Cisco Meraki Model MS220-8P.
jon
- BrianL2May 25, 2016NETGEAR Employee Retired
Hi jonl0711,
Well if you PC NIC card and OS supports NIC teaming, the transfer speed should improve. Just check this NETGEAR article for more information.
Kind regards,
BrianL
NETGEAR Community Team- StephenBMay 26, 2016Guru - Experienced User
Not always - it depends on the bonding mode being used. Round-robin likely would improve transfer speed. LACP normally won't, since each data flow is still limited to 1 gbit.
