jonl0711
Apr 30, 2016Aspirant
ReadyNAS Bonded Ethernet
I've recently purchase the RN314 and EDA500 unit. I would like to know can I bond the ethernet ports to a ProSafe 8-port Gigabit Ethernet Switch. I have around 10 TB of images I need to copy to th...
jonl0711
May 23, 2016Aspirant
The data is on internal drives on a RAID 5 setup.
They are raw files from the Canon Camera (.cr2) and each file is at least 25 MB in size.
I was wondering if I should put 2 NIC oin the PC and then try teaming to the switch,.
BTW the switch has been changed to a Cisco Meraki Model MS220-8P.
jon
BrianL2
May 25, 2016NETGEAR Employee Retired
Hi jonl0711,
Well if you PC NIC card and OS supports NIC teaming, the transfer speed should improve. Just check this NETGEAR article for more information.
Kind regards,
BrianL
NETGEAR Community Team
- StephenBMay 26, 2016Guru - Experienced User
Not always - it depends on the bonding mode being used. Round-robin likely would improve transfer speed. LACP normally won't, since each data flow is still limited to 1 gbit.
