alexstrong10
Nov 17, 2014Aspirant
ReadyNAS boot failure - pulsing power LED
Hi there I've had my ReadyNAS Duo for about five years. Until the other day, it's given me next to no problems, but I've currently got a serious issue and was after some help please: On booting,...
alexstrong10
Thanks for the reply. I've just edited my original post before realising your reply was there - the error code I originally described, and which your reply addresses, is when one disk (disk 2) is removed. When both disks are in, I get a pulsing power LED - four pulses followed by a single blink of the Act (activity? LED). No other LEDs blink.
The ReadyNAS is a Duo v1, bought May 2010. I tried earlier to do an OS reinstall (by holding down the reset switch with a paperclip for three seconds on power up, right?), but it did not appear to enter into reinstall mode, instead just booting as normal (if normal is the blinking LEDs I describe above!)
I'll have to hunt out my hard disk caddy from the garage in order to test the disks with vendor tools - a job for the weekend. In the meantime, to answer your other questions, yes I do fortunately have most of the data backed up (phew!); I can't recall which firmware is running, although I've tended to update it fairly regularly. AndI don't think ssh was enabled...
Thanks again.
Thanks again.
