Langzik_NAS
Jul 27, 2018Guide
ReadyNAS couldn't update Antivirus, then System volume 'root' usage was 85 %, now I can't boot...
Hi all,
I have 2 identical ReadyNAS 516 systems (with only different storage capacities and content); one is working fine, and the other one seems to have gone crazy. I am 99% certain that BOTH...
Jul 27, 2018Guru - Experienced User
I don't recommend an OS reinstall, as that will just try to put more files into the full OS partition.
You can still get paid netgear support at my.netgear.com. Also if you purchased between 1 June 2014 and 31 May 2016 you have lifetime chat support.
How proficient are you with the linux command line?
Wickedflies
Mar 18, 2019Aspirant
And how would I get into this lifetime chat support?. I fall between those purchase times. I think mine was 10-24-15. I'm having the same exact thing. Somthing about root at 92%.
- StephenBMar 19, 2019Guru - Experienced User
It should be available to you on my.netgear.com.
Turn off AntiVirus right away.
