Yeager44
Aug 04, 2018Aspirant
Readynas Data Volume Full - Stuck booting at 99%
Hello,
My data volume /data is full and my Readynas 516 is stuck booting at 99% (Status: System starting up). Is there a way to get past this so I can free up some space? I've looked at previou...
Aug 04, 2018Guru - Experienced User
One option is to use paid support (my.netgear.com). You'd boot the NAS in tech support mode, and they can fix it remotely. Note that If you purchased between 1 June 2014 and 31 May 2016, then you have lifetime chat support.
Do you know the status of the OS partition? If so, is it full also?
- Yeager44Aug 04, 2018Aspirant
Hello,
Thanks a bunch for your quick response. I can SSH into the NAS no problem, just can get to the web console. I purchased my NAS in April of 2014. I would definitely be willing to pay for support if thats the only option? Thanks again for your help.
Sorry meant to say I can't get to the web console. I can SSH into the box though.
- StephenBAug 04, 2018Guru - Experienced User
So you can see your files in /data from ssh? If so, you can delete some from there. You can also list and delete snapshots. btrfs subvolume list /data will give you the list of subvolumes (shares) and snapshots. You can then delete a snapshot using btrfs subvolume delete <path>
After you clean up the space, you might also need to finish with a btrfs balance (also from ssh).
Cleaning up the space might not solve your booting issue though.
