Yeager44
Aug 04, 2018Aspirant
Readynas Data Volume Full - Stuck booting at 99%
Hello,
My data volume /data is full and my Readynas 516 is stuck booting at 99% (Status: System starting up). Is there a way to get past this so I can free up some space? I've looked at previou...
Yeager44
Hi StephenB,
Thanks for the suggestion, I can list (btrfs subvolume list /data) the subvolumes, but unfortunately when trying to delete snapshots (btrfs subvolume delete /data/directoryname/.snapshots/XXX/snapshot) the command hangs.
Aug 04, 2018Guru - Experienced User
Is df showing that the volume is full, or is it btrfs fi df?
Do you have a full backup? If not, this would be a good time to make one. You can mount a USB drive manually.
Then maybe try
btrfs balance start -v -dusage=0 /data
This will reallocate any unused blocks to free space - which could free up a bit of free space.
- Yeager44Aug 05, 2018Aspirant
Hi Stephen,
Unfortunately, I can't mount the filesystem (btrfs -o ro /dev/md127 /mnt). When I try to it eventually says it can't read superblock. I am unable to mount/read the data in either normal or read-only boot mode. When I boot in normal mode it tries to mount the volume to /data and can't be unmounted at that point although I can successfully get results from "btrfs fi df -H /data" and "btrfs subvolume list /data" (after normal boot). How long does the balance usualy take. Thanks!# btrfs fi df -H /data
Data, single: total=13.71TB, used=13.69TB
System, DUP: total=8.39MB, used=1.41MB
System, single: total=4.19MB, used=0.00B
Metadata, DUP: total=19.33GB, used=17.72GB
Metadata, single: total=8.39MB, used=0.00B
GlobalReserve, single: total=536.87MB, used=0.00BHow long does the balance usually take?
Here is the df output:
# df -kh /dev/md127
Filesystem Size Used Avail Use% MouHnted on
/dev/md127 14T 13T 1.2T 92% /dataand also:
# btrfs fi us /data
Overall:
Device size: 13.62TiB
Device allocated: 12.50TiB
Device unallocated: 1.12TiB
Device missing: 0.00B
Used: 12.48TiB
Free (estimated): 1.13TiB (min: 589.40GiB)
Data ratio: 1.00
Metadata ratio: 2.00
Global reserve: 512.00MiB (used: 0.00B)
Data,single: Size:12.47TiB, Used:12.45TiB
/dev/md127 12.47TiB
Metadata,single: Size:8.00MiB, Used:0.00B
/dev/md127 8.00MiB
Metadata,DUP: Size:18.00GiB, Used:16.50GiB
/dev/md127 36.00GiB
System,single: Size:4.00MiB, Used:0.00B
/dev/md127 4.00MiB
System,DUP: Size:8.00MiB, Used:1.34MiB
/dev/md127 16.00MiB
Unallocated:
/dev/md127 1.12TiB- Yeager44Aug 05, 2018Aspirant
I also ran diagnostics and got the following:
Successfully completed diagnostics
System
Volume data is 91.67% full
Logs
2018-08-05 14:34:32: data.mount: Directory /data to mount over is not empty, mounting anyway.
2018-08-05 11:45:22: data.mount: Directory /data to mount over is not empty, mounting anyway.
2018-08-05 11:12:13: data.mount: Directory /data to mount over is not empty, mounting anyway.
2018-08-04 20:01:51: data.mount: Directory /data to mount over is not empty, mounting anyway.
2018-08-04 19:53:43: data.mount: Directory /data to mount over is not empty, mounting anyway.
2018-08-04 18:29:01: data.mount: Directory /data to mount over is not empty, mounting anyway.
2018-08-04 13:27:55: data.mount: Directory /data to mount over is not empty, mounting anyway.
2018-08-04 13:15:40: data.mount: Directory /data to mount over is not empty, mounting anyway.
2018-08-04 12:23:24: data.mount: Directory /data to mount over is not empty, mounting anyway.
2018-08-04 12:17:59: data.mount: Directory /data to mount over is not empty, mounting anyway.
System Management
2018-08-05 15:27:45: Failed to start ReadyNAS System Daemon.
2018-08-05 15:17:14: Failed to start ReadyNAS System Daemon.
2018-08-05 15:06:43: Failed to start ReadyNAS System Daemon.
2018-08-05 14:56:12: Failed to start ReadyNAS System Daemon.
2018-08-05 14:45:41: Failed to start ReadyNAS System Daemon.
