davidr1
Sep 11, 2016Luminary
ReadyNAS Diagnostic error
OS 6.5.1 2 x WD RED 1TB drives Hi Just did a diagnostics on my Ultra - errors were shown so I did a defrag. The result was: Successfully completed diagnostics System Logs 2016-09-12 09:5...
mdgm-ntgr
Sep 11, 2016NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
davidr1
Thanks mdgm,
Logs sent.
David
- mdgm-ntgrSep 12, 2016NETGEAR Employee Retired
sdc is an external disk. Have you run a filesystem check on that?
Also we have newer firmware. ReadyNAS OS 6.5.2 is now available!
- davidr1Sep 12, 2016Luminary
Thanks mdgm,
I'll run a fschk on the backup disk.
Isn't
2016-09-12 09:57:39: journalctl[4522]: segfault at 7f326292ee68 ip 00007f326a15bf71 sp 00007fff0d248100 error 4 in libsystemd-journal.so.0.0.3[7f326a159000+11000]
referring to memory (in the NAS)?
I have the NASUltra 2, NASPro and NAS314. None say an update is available.
I have downloaded the x86_64 update and will install it manually tonight.
- davidr1Sep 13, 2016Luminary
From my first post:
2016-09-12 09:57:39: journalctl[4522]: segfault at 7f326292ee68 ip 00007f326a15bf71 sp 00007fff0d248100 error 4 in libsystemd-journal.so.0.0.3[7f326a159000+11000]Can I remove this from showing every time I do a Diagnostic or is it the NAS itself that has a fault? I don't know what it means.
2016-09-02 09:21:17: EXT4-fs error (device sdc1): ext4_put_super:789: Couldn't clean up the journalWhat can I do to delete the journal?
2016-09-02 09:21:16: EXT4-fs error (device sdc1): ext4_journal_check_start:56: Detected aborted journalDitto.
I have checked my USB connected backup drives (sdc1 ?) and they have no errors.
Many thanks
David
